ERROR IN PARALLEL ANALYIS
Zeeshanbhat
Post by Zeeshanbhat » Wed Aug 30, 2023 6:04 pm
Dear Team,
I am currently facing an issue with STKO after not using it for the last 6-7 months. I had been utilizing OpenSeesMP for parallel analysis, and my models were performing well without any problems. However, upon revisiting my models and attempting to analyze them again in STKO, I encountered an error that states: "Can't read process ID - no such variable exists."
PROCESS ID.png (41.7 KiB) Viewed 3548 times
Additionally, I noticed that there have been some additions in the code
compared to the previous version.
STKO 2.png (36.91 KiB) Viewed 3548 times
The model is attached below:
Modelbi.zip
(251.91 KiB) Downloaded 263 times
I would greatly appreciate any assistance or guidance you could provide to help me resolve this error
Looking forward to your prompt response.
Best regards,
Zeeshan
Zeeshanbhat
Re: ERROR IN PARALLEL ANALYIS
Post by Zeeshanbhat » Thu Aug 31, 2023 6:01 pm
I have attached the model also. The model was running fine in previous version of STKO. None of my model is working now. Kindly help in this regard.
Zeeshan
Zeeshanbhat
Post by Zeeshanbhat » Tue Sep 05, 2023 8:15 am
Gentle Reminder
Post by STKO Team » Tue Sep 05, 2023 8:26 am
It's because you were running the analysis using a custom Tcl script that was compliant with the old STKO version.
However, now it should be sufficient to replace this line in your last analysis step:
I couldn't test it because I don't have your input GM, but let me know if it works
Zeeshanbhat
Post by Zeeshanbhat » Wed Sep 06, 2023 6:24 am
Dear Team,
Thank you for your assistance. I have analyzed the revised model with the correction you provided. Unfortunately, it is still displaying the same error.
I have attached the revised model along with the ground motion file for your reference. I kindly request your assistance in resolving this issue.
Thank you for your continued support.
Zeeshan Bhat
Modelbi.zip
(362.11 KiB) Downloaded 200 times
Post by STKO Team » Wed Sep 06, 2023 2:32 pm
You have to change also every instance of process_id with STKO_VAR_process_id
here's a modified file:
Modelbi.zip
(256.97 KiB) Downloaded 205 times
Zeeshanbhat
Post by Zeeshanbhat » Sat Sep 09, 2023 4:00 am
Thank you very much for your help.
Post by STKO Team » Mon Sep 11, 2023 2:11 pm
