I kindly seek assistance from anyone knowledgeable in this subject to provide guidance and support for the presented mod
beco
Post by beco » Mon Jul 08, 2024 9:11 am
Dear STKO Member,
I would like to express my sincere gratitude for the valuable help and support you have been providing to us learners. It is truly appreciated.
I have been trying to mimic one of the examples that you posted in the forum around 3 years ago regarding the application of load on a surface (slab). However, I am encountering a problem that I believe might be related to the nodes.
In the example, I was supposed to have only 8 nodes and 9 elements, with one face. However, I am instead seeing 10 nodes and 9 elements, with one face. I am not able to understand how the 4 nodes of the rectangular slab can be merged with the other 4 nodes of the upper column to form exactly 4 nodes. This node duplication might be the reason why my analysis is not able to converge.
I would be grateful if you could please take a look into this issue and provide me with some guidance. I have attached the model file in the window below.
Thank you in advance for your assistance. I look forward to your response.
Best regards,
Beco
help.rar
(88.49 KiB) Downloaded 145 times
Re: I kindly seek assistance from anyone knowledgeable in this subject to provide guidance and support for the presented
Post by kesavapraba » Wed Jul 10, 2024 9:19 am
Hi, You have combined the different geometries (drawn separately) using "compound" command, this will only group the geometry under a single name but still the geometries are separate. So, you will face convergence issue, like singularity. To avoid this, you should use "merge" command.
beco
Post by beco » Wed Jul 10, 2024 11:51 pm
@Prabakaran Kesavan,Thank you very much, It works very good.
Post by kesavapraba » Thu Jul 11, 2024 8:50 am
Hi, Happy to note that.
