Dear STKO Member,
I would like to express my sincere gratitude for the valuable help and support you have been providing to us learners. It is truly appreciated.
I have been trying to mimic one of the examples that you posted in the forum around 3 years ago regarding the application of load on a surface (slab). However, I am encountering a problem that I believe might be related to the nodes.
In the example, I was supposed to have only 8 nodes and 9 elements, with one face. However, I am instead seeing 10 nodes and 9 elements, with one face. I am not able to understand how the 4 nodes of the rectangular slab can be merged with the other 4 nodes of the upper column to form exactly 4 nodes. This node duplication might be the reason why my analysis is not able to converge.
I would be grateful if you could please take a look into this issue and provide me with some guidance. I have attached the model file in the window below.
Thank you in advance for your assistance. I look forward to your response.
Best regards,
Beco
I kindly seek assistance from anyone knowledgeable in this subject to provide guidance and support for the presented mod
- help.rar
- (88.49 KiB) Downloaded 145 times
Re: I kindly seek assistance from anyone knowledgeable in this subject to provide guidance and support for the presented
Hi, You have combined the different geometries (drawn separately) using "compound" command, this will only group the geometry under a single name but still the geometries are separate. So, you will face convergence issue, like singularity. To avoid this, you should use "merge" command.
@Prabakaran Kesavan,Thank you very much, It works very good.kesavapraba wrote: ↑Wed Jul 10, 2024 9:19 amHi, You have combined the different geometries (drawn separately) using "compound" command, this will only group the geometry under a single name but still the geometries are separate. So, you will face convergence issue, like singularity. To avoid this, you should use "merge" command.
Hi, Happy to note that.
