MPCORecorder Error: invalid response data size
hi.. I have problem with MPCORecorder, when I run my model, the .exe window says MPCORecorder Error: invalid response data size, and the fiber section data does not come out
Can someone help me?
- D400-TB-40ton.rar
- (102.49 KiB) Downloaded 152 times
Re: MPCORecorder Error: invalid response data size
It looks like the initStrain material has an issue with the number of components it gives as output.
Use the initStress instead (using an initial stress equal to your initial strain times the young's modulus): This has the same result as long as the init strain is less than the yield strain (which is the case in your example)
Thank you very much, it helps a lot
Dear STKO, I got the same problem if I select "element results (force)" in MPCORecorder
1/ Can you pleease check the attached file and give me a solution for it?
2/ How can I show the stress of the fiber section? (stress time history)
Thank,
Buu
Thank,
Buu
- Case 1_artificial_try.rar
- (750.73 KiB) Downloaded 60 times
it's because you are using the Triangle element and it has a similar issue to the initStrain material for the "force" output.
No worries, that output is generally not useful.
If you want to visualize stress use the material.stress output
Yeah, I see, Thank you very much for your support,
Buu
Buu
