MPCORecorder Error: invalid response data size
popovic
Post by popovic » Mon May 29, 2023 4:20 am
hi.. I have problem with MPCORecorder, when I run my model, the .exe window says MPCORecorder Error: invalid response data size, and the fiber section data does not come out
Can someone help me?
D400-TB-40ton.rar
(102.49 KiB) Downloaded 152 times
Re: MPCORecorder Error: invalid response data size
Post by STKO Team » Tue May 30, 2023 3:46 pm
It looks like the initStrain material has an issue with the number of components it gives as output.
Use the initStress instead (using an initial stress equal to your initial strain times the young's modulus):
This has the same result as long as the init strain is less than the yield strain (which is the case in your example)
popovic
Post by popovic » Wed May 31, 2023 1:18 am
Thank you very much, it helps a lot
Post by STKO Team » Wed May 31, 2023 2:24 pm
BuuNguyen
Contact:
Post by BuuNguyen » Mon Oct 28, 2024 5:22 am
Dear STKO, I got the same problem if I select "element results (force)" in MPCORecorder
1/ Can you pleease check the attached file and give me a solution for it?
2/ How can I show the stress of the fiber section? (stress time history)
Thank,
Buu
Case 1_artificial_try.rar
(750.73 KiB) Downloaded 59 times
Post by STKO Team » Tue Oct 29, 2024 9:42 am
it's because you are using the Triangle element and it has a similar issue to the initStrain material for the "force" output.
No worries, that output is generally not useful.
If you want to visualize stress use the material.stress output
BuuNguyen
Contact:
Post by BuuNguyen » Wed Oct 30, 2024 12:11 pm
Yeah, I see, Thank you very much for your support,
Buu
Post by STKO Team » Thu Oct 31, 2024 11:21 am
