PSUMAT - NOT DEFINED IN THIS VERSION, SOURCE CODE RESTRICTED
The clause “PSUMAT - NOT DEFINED IN THIS VERSION, SOURCE CODE RESTRICTED” is appeared when openseesmp solver is used to analyze LayeredShell section with PlaneStressUserMaterial and PlateFromPlaneStress. Analysis successfully finished after too long time with repeating that clause.
This issue is fixed when opensees solver is used.
Is there any subroutine or way to apply these materials for openseesmp solver?
Kind regards,
Rania
Kind regards,
Rania
- OpenseesMP_PSUMAT - NOT DEFINED IN THIS VERSION, SOURCE CODE RESTRICTED.png (68.45 KiB) Viewed 3174 times
- OpenseesMP_ANALYSIS SUCCESSFULLY FINISHED _ PSUMAT - NOT DEFINED IN THIS VERSION, SOURCE CODE RESTRICTED.png (606.26 KiB) Viewed 3174 times
Re: PSUMAT - NOT DEFINED IN THIS VERSION, SOURCE CODE RESTRICTED
It's simply because the source code for the psumat material is not available to the public. The owner put its code directly inside a library, but only for the sequential version on windows.
Thank you for your prompt reply.
1- To use DamageTC3D instead of PSUMAT material, I tried to analyze the model displayed in the webinar of Shear Wall. The analysis is completed, but unfortunately no damage is displayed (d+ d- equal 0 for all steps). Could I ask you about this matter, please?
2- Material tests for uniaxial and nD materials don’t work in last version 2.0.5 of the program. How could I fix this issue?
Best wishes,
Best wishes,
- No Damage.png (286.55 KiB) Viewed 3099 times
- Material Test_nD1.png (56.92 KiB) Viewed 3099 times
- Material Test_nD2.png (284.74 KiB) Viewed 3099 times
- Material Test_uniaxial1.png (42.2 KiB) Viewed 3099 times
- Material Test_uniaxial2.png (253.33 KiB) Viewed 3099 times
We are aware of that (not able to see the damage in fibers of shell).
Someone made a change in the latest OpenSees version that is in conflict with results on shell fibers other than strain and stress. We are trying to identify the issue and we will fix it soon in the next version.
Regarding the material tester, it was a bug in the very first release of the 2.0.5, if you download it again (2.0.5) the problem should be solved
Is PSUMAT available for parallel computing now? If not, is it possible to reach out to the developer to request implementation? Finally, is there any other similar material/element that can be used to model RC walls?
Thanks
Thanks
The source-code is not there.
However, we developed the ASDConcrete3D, which can be also used for 3D cases, while PSUMAT was only for plane-stress cases.
Ok. Thanks for quick response.
