PSUMAT - NOT DEFINED IN THIS VERSION, SOURCE CODE RESTRICTED
Rania. Ah
Post by Rania. Ah » Wed Dec 01, 2021 8:07 am
The clause “PSUMAT - NOT DEFINED IN THIS VERSION, SOURCE CODE RESTRICTED” is appeared when openseesmp solver is used to analyze LayeredShell section with PlaneStressUserMaterial and PlateFromPlaneStress. Analysis successfully finished after too long time with repeating that clause.
This issue is fixed when opensees solver is used.
Is there any subroutine or way to apply these materials for openseesmp solver?
Kind regards,
Rania
OpenseesMP_PSUMAT - NOT DEFINED IN THIS VERSION, SOURCE CODE RESTRICTED.png (68.45 KiB) Viewed 3175 times
OpenseesMP_ANALYSIS SUCCESSFULLY FINISHED _ PSUMAT - NOT DEFINED IN THIS VERSION, SOURCE CODE RESTRICTED.png
OpenseesMP_ANALYSIS SUCCESSFULLY FINISHED _ PSUMAT - NOT DEFINED IN THIS VERSION, SOURCE CODE RESTRICTED.png (606.26 KiB) Viewed 3175 times
Re: PSUMAT - NOT DEFINED IN THIS VERSION, SOURCE CODE RESTRICTED
Post by STKO Team » Wed Dec 01, 2021 3:38 pm
It's simply because the source code for the psumat material is not available to the public. The owner put its code directly inside a library, but only for the sequential version on windows.
Rania. Ah
Post by Rania. Ah » Tue Dec 28, 2021 10:47 am
Thank you for your prompt reply.
1- To use DamageTC3D instead of PSUMAT material, I tried to analyze the model displayed in the webinar of Shear Wall. The analysis is completed, but unfortunately no damage is displayed (d+ d- equal 0 for all steps). Could I ask you about this matter, please?
2- Material tests for uniaxial and nD materials don’t work in last version 2.0.5 of the program. How could I fix this issue?
Best wishes,
No Damage.png (286.55 KiB) Viewed 3100 times
Material Test_nD1.png (56.92 KiB) Viewed 3100 times
Material Test_nD2.png (284.74 KiB) Viewed 3100 times
Material Test_uniaxial1.png (42.2 KiB) Viewed 3100 times
Material Test_uniaxial2.png (253.33 KiB) Viewed 3100 times
Post by STKO Team » Tue Dec 28, 2021 11:57 am
We are aware of that (not able to see the damage in fibers of shell).
Someone made a change in the latest OpenSees version that is in conflict with results on shell fibers other than strain and stress. We are trying to identify the issue and we will fix it soon in the next version.
Regarding the material tester, it was a bug in the very first release of the 2.0.5, if you download it again (2.0.5) the problem should be solved
kolozvari
Post by kolozvari » Tue May 09, 2023 9:36 pm
Is PSUMAT available for parallel computing now? If not, is it possible to reach out to the developer to request implementation? Finally, is there any other similar material/element that can be used to model RC walls?
Thanks
Post by STKO Team » Wed May 10, 2023 2:09 pm
The source-code is not there.
However, we developed the ASDConcrete3D, which can be also used for 3D cases, while PSUMAT was only for plane-stress cases.
kolozvari
Post by kolozvari » Wed May 10, 2023 2:21 pm
Ok. Thanks for quick response.
Post by STKO Team » Thu May 11, 2023 7:58 am
