Is there any material in stko that can simulate nonlinear spring?
[email protected]
Post by [email protected] » Tue Mar 14, 2023 9:23 am
Dear stko team
Is there any material in stko that can simulate nonlinear spring?(Using zerolength element)
Its spring stiffness can not be a constant, but a customized curve
屏幕截图 2023-03-14 172300.png (29.45 KiB) Viewed 4141 times
Re: Is there any material in stko that can simulate nonlinear spring?
Post by STKO Team » Wed Mar 15, 2023 8:24 am
There are many. Try the Pinching4
[email protected]
Post by [email protected] » Fri Mar 17, 2023 2:23 pm
Dear stko team
i have two qusetions
(1)I saw physical properties from Pysimple and Tzsimple in stko.
If I build a two-dimensional model and want to use them to simulate the zerolength connection between the liquefied soil layer (quadup element 3dofs) and the underground structure (electrical beam column element 2dof)
Can I only use the zerolengthcontactASDimplex element? Is there any other zerolength element that can be used?
(2)If the underground structure is not a pile foundation, but a tunnel or subway station, can Pysimple1 and Tzsimple1 materials be used to simulate the contact between soil and structure?
Post by STKO Team » Fri Mar 17, 2023 5:00 pm
The zeroLengthASDimplex is for contact. If you want to use those 2 uniaxial material, use them with a standard zeroLength element.
Yes, with a standard zeroLength element as exaplained above
[email protected]
Post by [email protected] » Sat Mar 18, 2023 8:36 am
ummm..actully what I want to ask is whether the zeroLengthASDimplex element is the only zeroLength element used to connect 2dof and 3dof nodes
Post by STKO Team » Mon Mar 20, 2023 8:39 am
Oh yes, it's the only element that supports different DOFs at the 2 end-nodes.
With other elements, you need to duplicate nodes, and use the EqualDOF command to connect corresponding DOFs
