Dear stko team
Is there any material in stko that can simulate nonlinear spring?(Using zerolength element)
Its spring stiffness can not be a constant, but a customized curve
[email protected]
- 屏幕截图 2023-03-14 172300.png (29.45 KiB) Viewed 4144 times
Re: Is there any material in stko that can simulate nonlinear spring?
There are many. Try the Pinching4
[email protected]
Dear stko team
i have two qusetions
(1)I saw physical properties from Pysimple and Tzsimple in stko.
If I build a two-dimensional model and want to use them to simulate the zerolength connection between the liquefied soil layer (quadup element 3dofs) and the underground structure (electrical beam column element 2dof)
Can I only use the zerolengthcontactASDimplex element? Is there any other zerolength element that can be used?
(2)If the underground structure is not a pile foundation, but a tunnel or subway station, can Pysimple1 and Tzsimple1 materials be used to simulate the contact between soil and structure?
The zeroLengthASDimplex is for contact. If you want to use those 2 uniaxial material, use them with a standard zeroLength element.(1)I saw physical properties from Pysimple and Tzsimple in stko.
Yes, with a standard zeroLength element as exaplained above(2)If the underground structure is not a pile foundation, but a tunnel or subway station, can Pysimple1 and Tzsimple1 materials be used to simulate the contact between soil and structure?
[email protected]
ummm..actully what I want to ask is whether the zeroLengthASDimplex element is the only zeroLength element used to connect 2dof and 3dof nodes
Oh yes, it's the only element that supports different DOFs at the 2 end-nodes.
With other elements, you need to duplicate nodes, and use the EqualDOF command to connect corresponding DOFs
