Damage2p
cqf_2232
Damage2p
Post by cqf_2232 » Fri Jan 14, 2022 12:13 pm
Dear STKO team
I am using the 'Material Test' and an error occurs, what is the reason?In addition, 'Damage2p source code not available in this version' appears when I run the model, is it not supported by the latest version of STKO?
Re: Damage2p
Post by STKO Team » Tue Jan 18, 2022 6:14 pm
It is available only in the latest version of OpenSees (not OpenSeesSP or OpenSeesMP).
cqf_2232
Re: Damage2p
Post by cqf_2232 » Fri Jan 28, 2022 4:01 am
Hello, I used the latest OpenSees version (sequential) to run the model, and still prompted that the damage2p material does not exist in this version, am I understanding it wrong?
Re: Damage2p
Post by STKO Team » Fri Jan 28, 2022 2:38 pm
I checked the source code and it looks like they completely removed it from the repository.
You can try others ND material for concrete such as the DamageTC3D
cqf_2232
Re: Damage2p
Post by cqf_2232 » Mon Feb 07, 2022 2:12 am
Sorry, for some reason I want to use some ND materials from the opensees official website. I run STKO with opensees (official version), and after I follow the prompts to install it, it always fails to run. Could you please give me a detailed installation procedure for opensees (official version)?
Re: Damage2p
Post by STKO Team » Tue Feb 08, 2022 8:38 am
STKO automatically detects any OpenSees executables in the default folder C:\OpenSees-Solvers.
If you have your own OpenSees.exe somewhere else, you need to tell STKO where to find it, using the Kits command.
The procedure is described in the User manual: https://asdeasoft.net/pdf/STKOUserManual.pdf, at 2.9.4. Solvers.
Let us know if you have issues in following that procedure
Re: Damage2p
Post by marafini.f » Tue Feb 08, 2022 8:39 am
cqf_2232
Re: Damage2p
Post by cqf_2232 » Sat Feb 12, 2022 8:18 am
I'm not sure if my installation method is correct. First I put opensees (official version) to C:/OpenSees-solvers, then copy the hdf5 file to C:/OpenSees-solvers. Using STKO to run the model, the file cannot be read, what is the reason?
Re: Damage2p
Post by STKO Team » Mon Feb 14, 2022 10:03 am
Could you show how you set up the opensees solver kits by clicking on the "Kits" command?
Probably you forgot to use the placeholder for the TCL file name (#1)
cqf_2232
Re: Damage2p
Post by cqf_2232 » Wed Feb 16, 2022 11:47 am
OK, here's a screenshot of the Kits setup and the file location in OpenSees-Solvers. What is the correct operation?
