Damage2p
Damage2p
Dear STKO team
I am using the 'Material Test' and an error occurs, what is the reason?In addition, 'Damage2p source code not available in this version' appears when I run the model, is it not supported by the latest version of STKO?
- Damage2p source code not available in this version
- error.png (67.98 KiB) Viewed 4072 times
- error.png (17.33 KiB) Viewed 4082 times
- damage2p.png (73.5 KiB) Viewed 4082 times
Re: Damage2p
It is available only in the latest version of OpenSees (not OpenSeesSP or OpenSeesMP).
Re: Damage2p
Hello, I used the latest OpenSees version (sequential) to run the model, and still prompted that the damage2p material does not exist in this version, am I understanding it wrong?
- opensees.png (7.11 KiB) Viewed 4037 times
- warning.png (57.9 KiB) Viewed 4037 times
Re: Damage2p
I checked the source code and it looks like they completely removed it from the repository.
You can try others ND material for concrete such as the DamageTC3D
Re: Damage2p
Sorry, for some reason I want to use some ND materials from the opensees official website. I run STKO with opensees (official version), and after I follow the prompts to install it, it always fails to run. Could you please give me a detailed installation procedure for opensees (official version)?
Re: Damage2p
STKO automatically detects any OpenSees executables in the default folder C:\OpenSees-Solvers.
If you have your own OpenSees.exe somewhere else, you need to tell STKO where to find it, using the Kits command.
The procedure is described in the User manual: https://asdeasoft.net/pdf/STKOUserManual.pdf, at 2.9.4. Solvers.
Let us know if you have issues in following that procedure
Re: Damage2p
You can check here https://asdeasoft.net/?stko-requirements
Re: Damage2p
I'm not sure if my installation method is correct. First I put opensees (official version) to C:/OpenSees-solvers, then copy the hdf5 file to C:/OpenSees-solvers. Using STKO to run the model, the file cannot be read, what is the reason?
- Snipaste_2022-02-12_16-05-12.png (7.96 KiB) Viewed 3972 times
- Snipaste_2022-02-12_16-06-27.png (34.05 KiB) Viewed 3972 times
Re: Damage2p
Could you show how you set up the opensees solver kits by clicking on the "Kits" command?
Probably you forgot to use the placeholder for the TCL file name (#1)
Re: Damage2p
OK, here's a screenshot of the Kits setup and the file location in OpenSees-Solvers. What is the correct operation?
- Kits.png (6.53 KiB) Viewed 3964 times
- Location.png (66.01 KiB) Viewed 3964 times
