Extraction of Node Stresses During Post-Processing
Alessandro2016
Post by Alessandro2016 » Tue Jul 21, 2026 4:06 pm
I have a question and would appreciate your help. As far as I can tell, the current STKO calculation results only display stress values at Gauss points. I would like to further extract the stress calculation results at nodes. To that end, I’ve been learning how to use the Python API through webinars and the Python package for STKO v.2.0. I’ve now written some preliminary code to process the MPCO calculation results, as shown below:
from PyMpc import *
App.clearTerminal()
doc = App.postDocument()
db = doc.getDatabase(1)
stress = db.getElementalResult('stress',  match = MpcOdb.Contains)
s22_gauss = vr.comp(stress, 1)
db.removeNodalResult('Sigma 22')
s22 = vr.toNode(s22_gauss)
s22.setDisplayName('Sigma 22')
s22.setComponentLabels(['Sigma 22'])
db.addVirtualResult(s22)
s22 = db.getNodalResult('Sigma 22')
However, I’ve encountered an issue and am unable to determine the exact cause. When using STKO version 3.2.0, this code successfully retrieved the node stress results. However, when using a newer version of STKO, while the stress contour plot displays correctly, as shown in Figure 1, the “chart data” section remains empty, and the following error message appears:
Error: (MpcOdbReaderMakeScalarFieldHistory) Could not find the following nodes in the field data:
5331,
Abort Command: ExtractChartData
Could you please offer some advice? Is this code capable of effectively extracting node stress results, or how should I modify it to make it compatible with newer versions of STKO?
I hope I’ve explained my question clearly and look forward to your response.
figure1:
figure 1.jpg (138.35 KiB) Viewed 201 times
Best regards
Re: Extraction of Node Stresses During Post-Processing
Post by STKO Team » Mon Jul 27, 2026 8:19 am
Dear user,
Thank you for letting us know. We're resolving the bug soon, and the fix will be available with the next stko version.
In the meantime, you can extract a value at a node, ora emulate the extract chart data via python code (look at our first webinar on python api)
Actually any gauss result, when visualized in a surface plot, is extrapolated to the nodes, and optionally (with a checkbox) can be smoothed
Alessandro2016
Post by Alessandro2016 » Mon Jul 27, 2026 1:42 pm
Thank you for your reply. I'll try the method you suggested.
Best regards!
