Asd absorbing boundary conditions and saturated media
Aliyaghfoori
Post by Aliyaghfoori » Tue May 21, 2024 6:51 am
Dear Stko
Question1:
Can i use asd absorbing boundary condition around the saturated soil?
How can i free or fix water pressure degree of freedom?
Question2:
Can i define asd absorbing boundary conditions only on vertical boundary?
I want to model bedrock on the horizintal boundary.
Thanks
Re: Asd absorbing boundary conditions and saturated media
Post by STKO Team » Thu May 30, 2024 7:56 am
Yes
As usual. select the portion of the interior domain where you want to fix that DOF
Yes
Aliyaghfoori
Post by Aliyaghfoori » Sat Jun 01, 2024 5:59 pm
Dear STKO
Thank you for your reply.
I used ASD absorbing boundary conditions at the base of the plastic soil media. I imposed a velocity Ricker wavelet (related to the acceleration record with a maximum acceleration of 1g ).
when I record acceleration in the node on the base element(on the B(bottom ASD absorbing element)) the PGA is less than 1g.
Is the ASD absorbing boundary(B-element) damp and deamplify motion? I must enhance the velocity record?
Post by STKO Team » Mon Jun 03, 2024 7:53 am
can you share your file to have a look?
Aliyaghfoori
Post by Aliyaghfoori » Thu Jun 06, 2024 3:23 pm
Actually, I've developed my model directly in Tcl envinroment scripting.
Post by STKO Team » Tue Jun 18, 2024 8:14 am
It should be the same assuming the G and rho in the absorbing boundary match the material properties in the inner portion of the model
Aliyaghfoori
Post by Aliyaghfoori » Tue Jun 25, 2024 2:53 pm
Dear stko
I attached two picture of my model.
In 2D and saturated media i used:
Element:quad up
Material:PDMY
And asd absorbing boundary.
finally i want to define block deep soil in my models.
Acoording to pictures have i defined boundary condition correctly in undrained domain?
Thanks
Post by STKO Team » Mon Jul 29, 2024 2:20 pm
It seems fine.
Do this: try to use a simple Elastic Material and see if you obtain the expected results.
