Can not get a correct acceleration when running the example of absorbing boundary2D.
Thomas_CZX
Post by Thomas_CZX » Mon Jun 26, 2023 3:12 pm
I download the absorbing boundary2D example from STKO E-learning website,
2dexample.rar
(126.32 KiB) Downloaded 202 times
but when I run this example the acceleration time history curve oscillates violently.
The correct response should be something like below:
This is strange because it is just a simple 2D model with elastic material and absorbing boundary2D. I have checked every parameters are the same as in the video, and the size of the elements are already very small. Can you give me some suggestion about how to fix this problem? Many thanks!
Re: Can not get a correct acceleration when running the example of absorbing boundary2D.
Post by STKO Team » Mon Jun 26, 2023 4:01 pm
In the current OpenSees version, the TRBDF2 integrator does not work if the system is Linear with -factorOnce.
So you either uncheck the -factorOnce, or use Newmark or any other integrator
Thomas_CZX
Post by Thomas_CZX » Tue Jun 27, 2023 1:11 am
It works correctly now , many thanks for your guide!
Post by STKO Team » Wed Jun 28, 2023 4:45 pm
