The node model is not running
[email protected]
Post by [email protected] » Tue May 30, 2023 9:35 am
Dear stko operation team, good afternoon. I'm a beginner of stko. I've been writing TCL files before. Now it's very convenient to use stko.I built a node model based on experiments, and I wanted to get its hysteresis curve, but I couldn't run it in software. I checked for a long time but couldn't find the mistake. Could you please help me check it? thank。
001.rar
node
(111.83 KiB) Downloaded 172 times
ValentinaSB
Re: The node model is not running
Post by ValentinaSB » Tue May 30, 2023 11:00 am
The reason that you got the error is that you didn't use BeamSectionProperty.
Then I changed your selection set for c-node (it was given an error that there is more than 1 vertex)
Now you need to correct your hysteretic material, the values can not be the same, but you can make them with minimal differences. Also, you need to check your Joint2D material (Mat C is not assigned).
Let us know if you have any trouble.
Valentina
001.rar
(123.63 KiB) Downloaded 155 times
[email protected]
Post by [email protected] » Thu Jun 01, 2023 1:33 pm
THANK YOU!
Maybe you could tell me how to select the set for C-node.
I dont understant the meaning of it was given an error that there is more than 1 vertex
ValentinaSB
Post by ValentinaSB » Thu Jun 01, 2023 3:05 pm
You are welcome.
If you try to add BeamSectionProperty to your old file by yourself and you try to run it, you will see this error.
Screenshot 2023-06-01 170258.jpg (35.55 KiB) Viewed 1678 times
The error tells you that in c_node selection set is more than one vertex. To solve it I deleted and created again the c_node selection set. Just this. I saw that it is one vertex now in your model, but something went wrong while you were modeling and you end up with two more geometries stored in your selection set that do not exist anymore. We will look into it, but the solution for you is to delete and create it again as I did. I hope I was more clear this time.
Valentina
