brace deformed shape
In the STKO post-processing process, the support of the deformation diagram is disconnected. where problem went wrong?
- brace example.zip
- (452.22 KiB) Downloaded 310 times
- knee brace.jpg (275.22 KiB) Viewed 4334 times
have a pattern
Re: brace deformed shape
You probably did nor merge the geometry, please check it.
I merged geometry from the beginning
- 002.png (366.39 KiB) Viewed 4248 times
have a pattern
It's a single Wire, but the edges on top do not pass through the brace-end-node (as you can see here, it is a single edge, not physically intersecting the brace-end-node):
What You should do is to delete those edges, draw them again as a 3-point, 2-edge lines passing through the brace end-node, and make the wire again:
Finally, you re-assign material and element properties.
Here is the modified file
Thank you for your detailed explanation. But the deformation pattern is still abnormal.It's not the same as the metamorphosis I had in ETabs.It's been going on for a long time. I can't get the right results.
- 00.png (27.61 KiB) Viewed 4172 times
- experience.zip
- (17.95 MiB) Downloaded 326 times
- 000.png (216.43 KiB) Viewed 4181 times
have a pattern
There were some mistakes in the analysis settings:
Check this:
- You put both gravity and lateral loads during the gravity analysis. The pushover load should be added after the gravity!
- After the gravity you should use -loadConst (too keep the gravity load constant) and reset the pseudoTime to 0! this is very important in disp-control analysis
- Minor improvement: you are using a single Finite Element per structural member. In this case you need the Force-Based beam element, not the Displacement-Based (which needs a refined mesh)
- You forgot to put the GJ value to the fiber section (it can be singular in torsion)
Check this:
