brace deformed shape
zhangs
Post by zhangs » Mon Aug 08, 2022 3:51 pm
In the STKO post-processing process, the support of the deformation diagram is disconnected. where problem went wrong?
brace example.zip
(452.22 KiB) Downloaded 310 times
knee brace.jpg (275.22 KiB) Viewed 4335 times
have a pattern
Lucy2012
Re: brace deformed shape
Post by Lucy2012 » Wed Aug 10, 2022 6:32 pm
You probably did nor merge the geometry, please check it.
zhangs
Post by zhangs » Mon Aug 15, 2022 1:45 am
I merged geometry from the beginning
have a pattern
Post by STKO Team » Mon Aug 22, 2022 12:53 pm
It's a single Wire, but the edges on top do not pass through the brace-end-node (as you can see here, it is a single edge, not physically intersecting the brace-end-node):
What You should do is to delete those edges, draw them again as a 3-point, 2-edge lines passing through the brace end-node, and make the wire again:
Finally, you re-assign material and element properties.
Here is the modified file
0010.zip
(150.16 KiB) Downloaded 315 times
zhangs
Post by zhangs » Tue Aug 23, 2022 1:59 am
Thank you for your detailed explanation. But the deformation pattern is still abnormal.It's not the same as the metamorphosis I had in ETabs.It's been going on for a long time. I can't get the right results.
experience.zip
(17.95 MiB) Downloaded 326 times
have a pattern
Post by STKO Team » Tue Aug 23, 2022 11:37 am
There were some mistakes in the analysis settings:
  • You put both gravity and lateral loads during the gravity analysis. The pushover load should be added after the gravity!
  • After the gravity you should use -loadConst (too keep the gravity load constant) and reset the pseudoTime to 0! this is very important in disp-control analysis
  • Minor improvement: you are using a single Finite Element per structural member. In this case you need the Force-Based beam element, not the Displacement-Based (which needs a refined mesh)
  • You forgot to put the GJ value to the fiber section (it can be singular in torsion)
I also added a monitor to monitor in real-time the pushover curve
Check this:
0010.zip
(156.68 KiB) Downloaded 330 times
