Dear Sir/Madam
I tried to run my model in OpenSeesMP with three partition. I get the message that I have attached herewith. But, after the message pop-up window, nothing happens, analysis does not take place! I use Windows 7 OS. Can you please guide me to fix this issue? Should I install something? Thanks in advance.
Analysis not proceeding in parallel mode
- ErrorMsg.PNG (43.96 KiB) Viewed 4011 times
Re: Analysis not proceeding in parallel mode
Did you partition your model correctly?
You can attach it to your post so we can try and run it ourselves.
Unfortunately the parallel version of OpenSees compiled by prof. Tarque does not work on WIndows 7.
Noted with thanks.
yakabdullahi
Man, that issue sounds pretty frustrating. I've had a similar experience with OpenSeesMP before, but I was able to find a solution. First off, I'd suggest making sure you've got the latest version of OpenSeesMP and double-check that your partitions are properly set up. Now, about your Windows 7 OS, you might want to consider upgrading to Windows 10 or even Windows 11. A lot of software is more compatible with the newer versions, and it could possibly help fix your issue. I know upgrading can be a bit pricey, but I found a sweet deal on a cheap windows activation key from a reddit windows keys article a while back. It worked like a charm for me, and I haven't had any major issues since.
Sure. Thank you for your input.
