Analysis not proceeding in parallel mode
Post by kesavapraba » Tue Feb 08, 2022 5:56 am
Dear Sir/Madam
I tried to run my model in OpenSeesMP with three partition. I get the message that I have attached herewith. But, after the message pop-up window, nothing happens, analysis does not take place! I use Windows 7 OS. Can you please guide me to fix this issue? Should I install something? Thanks in advance.
Re: Analysis not proceeding in parallel mode
Post by marafini.f » Tue Feb 08, 2022 8:40 am
Did you partition your model correctly?
You can attach it to your post so we can try and run it ourselves.
Post by STKO Team » Tue Feb 08, 2022 9:13 am
Unfortunately the parallel version of OpenSees compiled by prof. Tarque does not work on WIndows 7.
Post by kesavapraba » Tue Feb 08, 2022 10:06 am
Noted with thanks.
yakabdullahi
Post by yakabdullahi » Sun Apr 02, 2023 8:19 pm
Man, that issue sounds pretty frustrating. I've had a similar experience with OpenSeesMP before, but I was able to find a solution. First off, I'd suggest making sure you've got the latest version of OpenSeesMP and double-check that your partitions are properly set up. Now, about your Windows 7 OS, you might want to consider upgrading to Windows 10 or even Windows 11. A lot of software is more compatible with the newer versions, and it could possibly help fix your issue. I know upgrading can be a bit pricey, but I found a sweet deal on a cheap windows activation key from a reddit windows keys article a while back. It worked like a charm for me, and I haven't had any major issues since.
Post by kesavapraba » Mon Apr 03, 2023 2:15 am
Sure. Thank you for your input.
