Material property curve export\import
Hi, is there a way to export the material curves from STKO, as we see them in the TEST phase? In order to be able to reconstruct them externally in excel.
Or similarly, is there a way to insert a material curves into STKO based on points entered by the user?
Thanks
Thanks
Re: Material property curve export\import
Not in the current version, but it will be in the next one.Hi, is there a way to export the material curves from STKO, as we see them in the TEST phase?
In the meantime, here is a workaround:
Replace these files in C:\Program Files\STKO\external_solvers\opensees\physical_properties\utils\tester
(You will need Admin privileges for this)
From now on, when you run a material Tester you will find and output.txt file in
- C:\Users\<Your PC User Name>\AppData\Local\ASDEA Software Technology\STKO\Tester1D (for uniaxial materials)
- C:\Users\<Your PC User Name>\AppData\Local\ASDEA Software Technology\STKO\TesterND (for ND materials)
The columns in those files are:
1) percentage of the test (from 0 to 1)
2) strain (1 component for uniaxial, 3 or 6 for ND)
3) stress (1 component for uniaxial, 3 or 6 for ND)
Hi!
I had the previous version of the software and downloaded the new version (STKO-2.0.1). I couldnt obtain the output file when performing a material tester with none of the versions. I updated the files with the ones attached in this post and then the material tester created the file.
The date of the previous files were older than these new ones.
If you don't want the output file to be deleted automatically, you need to comment the highlighted line in the files
C:\Program Files\STKO\external_solvers\opensees\physical_properties\utils\tester\Tester1D.py (and TesterND.py for 3D materials)
I tried to follow this instruction, but it did not work work.STKO Team wrote: ↑Mon Nov 09, 2020 9:35 amNot in the current version, but it will be in the next one.Hi, is there a way to export the material curves from STKO, as we see them in the TEST phase?
Replace these files
tester.zip
From now on, when you run a material Tester you will find and output.txt file inNote: the AppData is a hidden directory, you need to show Hidden directories.
I have replace the file tester.zip. When I tried to test my material, there was not a output.txt in the directory.
- Screenshot_29.png (159.92 KiB) Viewed 3699 times
- Screenshot_28.png (85.8 KiB) Viewed 3699 times
It should have worked.I tried to follow this instruction, but it did not work work.
However, now we have a better solution, it will be available in the next (V 2.0.2) STKO version.
In the meantime, I attach here 3 modified python files (zipped) to be extracted in:
replacing the existing ones (Tester1D.py, TesterND.py and GuiUtils.py)
It works. Thanks, STKO!STKO Team wrote: ↑Wed Mar 31, 2021 10:38 amIt should have worked.I tried to follow this instruction, but it did not work work.
tester.zip
You're welcome, good luck with your modeling!
