Material property curve export\import
Telec
Post by Telec » Mon Nov 09, 2020 8:58 am
Hi, is there a way to export the material curves from STKO, as we see them in the TEST phase? In order to be able to reconstruct them externally in excel.
Or similarly, is there a way to insert a material curves into STKO based on points entered by the user?
Thanks
Re: Material property curve export\import
Post by STKO Team » Mon Nov 09, 2020 9:35 am
Not in the current version, but it will be in the next one.
In the meantime, here is a workaround:
Replace these files
tester.zip
(18.16 KiB) Downloaded 259 times
in C:\Program Files\STKO\external_solvers\opensees\physical_properties\utils\tester
(You will need Admin privileges for this)
From now on, when you run a material Tester you will find and output.txt file in
  • C:\Users\<Your PC User Name>\AppData\Local\ASDEA Software Technology\STKO\Tester1D (for uniaxial materials)
  • C:\Users\<Your PC User Name>\AppData\Local\ASDEA Software Technology\STKO\TesterND (for ND materials)
Note: the AppData is a hidden directory, you need to show Hidden directories.
The columns in those files are:
1) percentage of the test (from 0 to 1)
2) strain (1 component for uniaxial, 3 or 6 for ND)
3) stress (1 component for uniaxial, 3 or 6 for ND)
mmc
Post by mmc » Tue Mar 23, 2021 11:35 am
Hi!
I had the previous version of the software and downloaded the new version (STKO-2.0.1). I couldnt obtain the output file when performing a material tester with none of the versions. I updated the files with the ones attached in this post and then the material tester created the file.
The date of the previous files were older than these new ones.
Post by STKO Team » Tue Mar 23, 2021 3:47 pm
If you don't want the output file to be deleted automatically, you need to comment the highlighted line in the files
C:\Program Files\STKO\external_solvers\opensees\physical_properties\utils\tester\Tester1D.py (and TesterND.py for 3D materials)
Immagine 2021-03-23 164554.png (46.14 KiB) Viewed 3723 times
darmawan
Post by darmawan » Wed Mar 31, 2021 8:13 am
Replace these files
tester.zip
I tried to follow this instruction, but it did not work work.
I have replace the file tester.zip. When I tried to test my material, there was not a output.txt in the directory.
Post by STKO Team » Wed Mar 31, 2021 10:38 am
It should have worked.
However, now we have a better solution, it will be available in the next (V 2.0.2) STKO version.
In the meantime, I attach here 3 modified python files (zipped) to be extracted in:
replacing the existing ones (Tester1D.py, TesterND.py and GuiUtils.py)
tester.zip
(17.33 KiB) Downloaded 247 times
Immagine 2021-03-31 123723.png (121.73 KiB) Viewed 3687 times
darmawan
Post by darmawan » Wed Mar 31, 2021 3:13 pm
tester.zip
It works. Thanks, STKO!
Post by STKO Team » Thu Apr 01, 2021 9:58 am
You're welcome, good luck with your modeling!
