can not write the tcl file
thanh2611
Post by thanh2611 » Fri Feb 14, 2020 2:53 am
My name is Thanh, I have a problem with writing the result file. In below, it is a capture of my problem.
Thank you so much for your help
MaurizioB
Re: can not write the tcl file
Post by MaurizioB » Fri Feb 14, 2020 9:11 am
DearThanh,
The element you are using needs this physical property: BeamSectionProperty:
Watch this video to learn more:https://www.youtube.com/watch?v=vPB9ZwT ... e=youtu.be
thanh2611
Post by thanh2611 » Sat Feb 15, 2020 6:03 am
Thank you so much
thanh2611
Post by thanh2611 » Mon Feb 17, 2020 1:45 am
Dear sir,
I already implemented physical property in for my element but it still does not work.
Post by STKO Team » Tue Feb 18, 2020 8:54 am
Please can you post the error you are having?
One note: from the image I think you are doing a 2D example, but your model is in XZ plane. In OpenSees, for a 2D problem, you need to draw everything in the XY plane.
