My name is Thanh, I have a problem with writing the result file. In below, it is a capture of my problem.
Thank you so much for your help
can not write the tcl file
- Capture.PNG (33.44 KiB) Viewed 4493 times
Re: can not write the tcl file
DearThanh,
The element you are using needs this physical property: BeamSectionProperty: Watch this video to learn more:https://www.youtube.com/watch?v=vPB9ZwT ... e=youtu.be
Thank you so much
Dear sir,
I already implemented physical property in for my element but it still does not work.
- 1.PNG (176 KiB) Viewed 4470 times
Please can you post the error you are having?
One note: from the image I think you are doing a 2D example, but your model is in XZ plane. In OpenSees, for a 2D problem, you need to draw everything in the XY plane.
