beam_solid_bar_slip
ssimon
beam_solid_bar_slip
Post by ssimon » Fri Dec 06, 2024 2:18 pm
I tried to simulate a rebar and concrete model of a tunnel to consider the famous "03_beam_solid_bar_slip.scd"
I want to consider the bond between concrete and rebar, but the running result does not show the stress and strain of the rebar, I checked the model and I don't know where there is a problem, could you help me ? (see attached "*.scd" model).
Best wishes
circle_rebar.7z
(642.12 KiB) Downloaded 86 times
Re: beam_solid_bar_slip
Post by STKO Team » Mon Dec 09, 2024 2:46 pm
If the beam is modelled with a fiber section, you need to ask for the section.fiber.stress and section.fiber.strain results, and plot them with a Fiber Plot
ssimon
Post by ssimon » Tue Dec 10, 2024 7:07 am
THANKS! I think I already know how to show the stresses , but what I show is the figure below,It's not clear to me why there is such points?
Post by STKO Team » Tue Dec 10, 2024 3:48 pm
If you isolate the inner solid and plot a (very) deformed shape you will see that you have a gap in your geometry
ssimon
Post by ssimon » Wed Dec 11, 2024 2:40 am
It's amazing, thank you.
Post by STKO Team » Wed Dec 11, 2024 9:55 am
ssimon
Post by ssimon » Fri Dec 13, 2024 9:29 am
Hello, I still have a few questions:
1. Is my unit N, mm, and the b3 coefficient of element -9.8? Or is it -9800?
2. If I want to change to KN, m, what do I need to do in the units in ASD concrete3D material?
3. If I want to apply ground motion to the soil, use the addition of groundmotion or the addition of Uniform Excitation Pattern。
Thank you for your help !
Post by STKO Team » Fri Dec 13, 2024 10:50 am
You have to be consistent: -9800 mm/s^2
As before: you have to be consistent. Just change the Young's modulus and the fc to kN/m^2.
If you are using one of the presets, you can simply input the units you are using for force (kN) and displacement (m) and it will automatically compute the other parameters with the proper units.
You can do both, but if your soil is actually an infinite medium, use the ASDAbsorbingBoundary (check our webinars)
ssimon
Post by ssimon » Sun Dec 15, 2024 5:09 am
would you mind to recommend me a related link? Learning videos or examples on adding ground motion, adding a uniform excitation mode, and ASDAbsorbingBoundary?
ssimon
Post by ssimon » Sun Dec 15, 2024 10:43 am
Hello, STKO team:
I have questions, if the model built with FF and LK is the model I built correct or the deformation is too large so that I can't find out where is the erorr?
By the way, If we use ASDAbsorbingBoundary , is it possible to analyze the soil model with FluidSolidPorousMaterial?
I can't thank you enough
FF-LK.zip
(1.47 MiB) Downloaded 108 times
