erro while creating input files
bruznunez
Post by bruznunez » Fri Sep 20, 2024 9:48 pm
I write to ask for help with a message that tells me the program when trying to run the model. I have followed the instructions shown in the webinars but now I see the following image that is attached in the email. Please request help promptly.
Best regards.
masonry_wall_6.zip
(766.18 KiB) Downloaded 66 times
Re: erro while creating input files
Post by kesavapraba » Mon Sep 23, 2024 4:33 am
Hi, You have incorrecctly assigned beam element(line element) to surfaces. You can use ASDShellQ4 shell element with ElasticMembranePlateSection section properties instead of beam element for the surfaces.
bruznunez
Post by bruznunez » Tue Sep 24, 2024 7:39 pm
Hello thank you very much, I corrected the mentioned error but now it shows me another problem.
Error message.png (833.6 KiB) Viewed 1818 times
bruznunez
Post by bruznunez » Tue Sep 24, 2024 7:48 pm
I corrected the above by adding more lines to the geometry and now I see the following error. I don’t understand what it refers to.
bruznunez
Post by bruznunez » Tue Sep 24, 2024 7:51 pm
i forgot the picture, here is.
Error message_2.png (686.2 KiB) Viewed 1817 times
Post by kesavapraba » Wed Sep 25, 2024 5:34 am
Can you please share the model? Error in the picture is not clear to me
bruznunez
Post by bruznunez » Wed Sep 25, 2024 9:23 am
Sure, here is the current model.
shear wall_6.zip
(180.75 KiB) Downloaded 59 times
Post by STKO Team » Thu Sep 26, 2024 8:09 am
You are using an elastic beam section for a shell.
You should use section->ElasticMembranePlateSection
