Gap simualtion
Lei Lei
Re: Gap simualtion
Post by Lei Lei » Mon Mar 25, 2024 2:07 pm
Thanks for your reply!
Could you please delete the attachment for confidentiality?
Thanks~
Re: Gap simualtion
Post by STKO Team » Thu Apr 04, 2024 8:41 am
done
Lei Lei
Re: Gap simualtion
Post by Lei Lei » Thu Apr 04, 2024 8:44 am
Thanks for your kindness!
Best wishes!
Re: Gap simualtion
Post by STKO Team » Thu Apr 04, 2024 9:55 am
Lei Lei
Re: Gap simualtion
Post by Lei Lei » Mon Apr 08, 2024 5:40 am
Dear STKOteam,
The problem I mentioned is still not solved.
Lei Lei wrote:
Mon Mar 18, 2024 1:39 am
Therefore, I used an 'aggregator' to give shear resistance to the joint, but It reported errors.
It can compute successfully when I forgive using the 'MPCORecorder' command.
What's the reason for it? The version of STKO is 3.3.0 and of Opensees solver is 3.4.0.
The error message is just like picture below:
error mesage
Lei Lei
Re: Gap simualtion
Post by Lei Lei » Thu Apr 11, 2024 2:21 am
Dear STKOteam,
For this problem, I tried my case with an earlier version 3.1.0 of STKO and it worked properly.
Maybe there are some bugs in the current version?
And where can I download the earlier version of STKO?
The error message is just like the picture below:
Re: Gap simualtion
Post by STKO Team » Tue Apr 23, 2024 8:04 am
Can you share your STKO file?
The error is in the MPCORecorder during the opensees analysis. Probably due to an element that does not format the results correctly
Lei Lei
Re: Gap simualtion
Post by Lei Lei » Wed Apr 24, 2024 5:22 am
Yes, here is a simple case.
By the way, I tried it on another computer and it worked while it couldn't on mine.
Maybe I should reinstall it? Or is there something lost in my notebook?
Re: Gap simualtion
Post by STKO Team » Mon Apr 29, 2024 8:08 am
Are you sure you attached the same file?
I don't have that error with OpenSees 3.4.0 (try to download again the OpenSees-Solvers from prof. tarque's website).
Second, I see problems in this model: 1) the MPCORecorder is at the end, and 2) the selection set for the control node is empty
Lei Lei
Re: Gap simualtion
Post by Lei Lei » Mon Apr 29, 2024 10:10 am
Dear,
I reinstalled the OpenSees 3.4.0 from https://www.researchgate.net/publicatio ... r_OpenSees.
However, the mistake still exists. Figure1.
Here is a debug model for the original one.
Looking forward to your reply.
