MESH ERROR SOIL DOMAIN
Re: MESH ERROR SOIL DOMAIN
Thanks a lot vey clear.
One more question please. What do you think about the ANALYISIS STEPS I am considering? Because I saw in webinars about SSI you used the material nd.Initial.Analysis.Wrapper and you change all the Analysis Steps.
I´ve attached the Analysis Steps that I´m considering.
- captura Analys step.png (15.41 KiB) Viewed 5126 times
This seems fine.
However, when you have soil + structure, it's more reasonable to first build the soil and analyze it with its own self weight.
The you reset the displacement to zero, keeping the stress from the self weight (InitialStateAnalysis).
At this point you can add a structure.
The reason for this is that the structure is build when the soil is already in the deformed configuration with the state of stress derived from its own self weight
Thanks a lot.
Now, I put initial state condition, but I had a problems with the convergence, please your help
I´ve attached the model and the mistake.
- 01-TESIS DOS PISOS COMPLETO CON SOTANOS CAPAS LAPTOP.rar
- (435.58 KiB) Downloaded 240 times
- error1.png (52.79 KiB) Viewed 5102 times
I tried to have a look at your model but I cannot fix it because some parts of the model are not clear to me.
However, the error is in how you use the addModelSubset command.
In your file you added only 1 modelSubset, with the soil, the interactions in the soil only (edofs) and some interactions between soil and structure.
The procedure should be this instead:
- addModelSubset: soil and interactions between soil parts ONLY!
- add constraints and load patterns acting ONLY on the selection sets previously added with the modelSubset of the soil
- do the initial state on / gravity / initial state off
- addModelSubset: structure and interactions structure-structure (like rigid diaphragms) and soil-structure (contacts, etc..)
- add constraints and load patterns acting ONLY on the selection sets previously added with the modelSubset of the structure
Thanks a lot
I understand your recommendation but when I've model the addModelSubset just soil and interactions between soil parts I had a different mistake.
I´ve attached the error with the model
Please your help
PD: In this point I´ve just to want run the first part I mean just the soil because If I get to run the firs initial condition the second (structure) will be easier.
Please your help
- error2.png (65.55 KiB) Viewed 5095 times
- (431.41 KiB) Downloaded 265 times
There were still errors with the model stages.
For example here you added the embedded constraints that links the soil to the structure, but at this point the structure is not yet in opensees (that's why you have the error): Here's a working file: You just need to put some nodes in the "TOP NODES" selection set, because it's empty, and the monitor is not recording anything
Dear STKO team
Thanks a lot for your time I really appreciate that.
The model that you sent me doesn't work. Maybe you took some consideration before the run the model?
- error3.png (85.49 KiB) Viewed 5088 times
The model is working fine for me.
Make sure to install the latest versions of both STKO and OpenSees-Solvers. And make sure you are using OpenSeesMP (according to your analysis settings)
- fine.png (256.15 KiB) Viewed 5084 times
Dear STKO team
I want to say thank you. I really apreciate this forum, It´s really helpful and so kindness. I hope with this last advice I finsish my investigation, thanks a lot
Best regardings
allano89
Best regardings
allano89
