Dear SKTO team,
I am trying to model a post-tension bar, I used steel01 material and initialstrain material to add PT force, then assigned truss element. When I run the model the error said physical property must be section, I added a section in special purpose, Do you have any ideas to fix the issue?
Thanks,
Da
physical property must be section not special purpose
- error.png (106.85 KiB) Viewed 1741 times
- PT.zip
- (86.57 KiB) Downloaded 167 times
Re: physical property must be section not special purpose
It's because you are using a corotTrussSection, which expects a section (like a fiber section for composite trusses).
In your case you just need a corotTruss:
Thanks! working now
you're welcome
