Damage2p
Re: Damage2p
Post by STKO Team » Wed Feb 16, 2022 2:50 pm
The "Command" field for your manual kit should be:
C:/OpenSees-Solvers/bin/OpenSees.exe #1
The #1 is a placeholder for the file name that STKO will generate.
Also, copy all the HDF5 DLLs in the same folder where you have the OpenSees.exe, otherwise, it will not be able to find them.
cqf_2232
Re: Damage2p
Post by cqf_2232 » Thu Feb 17, 2022 2:01 am
I can run opensees (official version) according to what you said, but I found that this version does not seem to have the ND material of Damage2p. But OpenSees official website still has this material introduction, what is the reason?
not available.png (49.12 KiB) Viewed 1816 times
Re: Damage2p
Post by STKO Team » Thu Feb 17, 2022 9:45 am
Probably it has been removed also from the Official version.
I know, but the OpenSees documentation is not always up-to-date with the current changes...
Anyway, that material model is very similar to our DamageTC3D, try to use it instead
cqf_2232
Re: Damage2p
Post by cqf_2232 » Thu Feb 17, 2022 10:59 am
Ok,thank you.
