Error in analysis
Telec
Error in analysis
Post by Telec » Tue Nov 03, 2020 1:23 pm
i am trying to do an analysis with openseesMP. I followed the directions in this post viewtopic.php?f=38&t=1642
to transform the analysis from sequential to MP. I get this error though:
HC2020
Re: Error in analysis
Post by HC2020 » Tue Nov 03, 2020 2:20 pm
You are receiving this error because you are using DamageTC3D which is not in the public repository of OpenSees. It is built as an external plugin available in the OpenSees version precompiled by prof. Tarque. You can download it here:
At the bottom of that webpage you will find a google drive link that will let you download the installer:
https://drive.google.com/file/d/1ETGQ3Y ... sp=sharing
This is a standard windows 10 installer that will install OpenSees and OpenSeesMP (and all the necessary dependencies) in C:/OpenSees-Solvers and STKO will automatically detect them once installed. Try to use them and see if the error persists.
Telec
Post by Telec » Tue Nov 03, 2020 2:53 pm
I've already downloaded and installed that version.
Post by STKO Team » Tue Nov 03, 2020 3:26 pm
If you already downloaded that version there should be no problem.
You are having that error because it says that it cannot find HDF5 libraries.
However they are there.
  • First make sure you are selecting the proper openseesmp:
  • Make sure you have the following libraries in C:\OpenSees-Solvers\hdf5:
  • Finally, make sure you don't have accidentally changed the contents of the openseesmp.bat file in C:\OpenSees-Solvers:
Telec
Post by Telec » Tue Nov 03, 2020 4:12 pm
ok now it works.
hdf5.so was missing.
I reinstalled again the package.
THX
