So, when I try to execute OpenSeesMP.exe, installed from OpenSees-Solvers-1.0.1-Installer.exe (Nicola Tarque), the "OpenSeesMP.exe has stopped working" window will immediately pop up
I uninstalled a previous version of MPICH2 and it still did'nt work. I have tried running it as and admin too with no luck.
The sequential version OpenSees.exe is running well.
Has anyone had this problem before?
Kind regards
Pablo
OpenSeesMP.exe won't open
Re: OpenSeesMP.exe won't open
I don't know if you did but do not install MPICH or any other MPI library on your computer. I did this before and it really messed my computer that I couldn't solve it how hard I try.
Prof Tarque's pack has a built in MPI library. I reinstalled a clean Windows and only installed Prof. Tarque's pack and it is running well now.
Vefa OKUMUS
MSc. Structural Engineer
PhD candidate.
Software Developer.
Istanbul - Turkey
PhD candidate.
Software Developer.
Istanbul - Turkey
Thanks vokumus for the reply. Probably you need to find on the web a detailed tutorial on how to completely un-install MPICH2 from your PC. Probably a simple un-install will not clear all the feature and registry changes the original installation did.
I would like to remind that some antivirus and firewall softwares can block mpiexec.hydra software so it is good to define proper exceptions.
Vefa OKUMUS
PhD candidate.
Software Developer.
Istanbul - Turkey
PhD candidate.
Software Developer.
Istanbul - Turkey
