Get the latest version of OpenSEES MP/SP
yuweihwang
Hello
OpenSEES recently release the new version of OpenSEES MP V3.2 and SP V3.2.
Is there any way to download those versions of exe files and connect it with STKO?
I tried to download those files from https://opensees.berkeley.edu/OpenSees/ ... rallel.php
However, they didn't allow us to download the files.
Thanks for any help!
Re: Get the latest version of OpenSEES MP/SP
Hi!
it is possible to download lasts version of OpenSEES at the following link.
posting.php?mode=reply&f=28&t=1633
STKO will automatically use the last version installed on C, but you can check it on Edit Solver Kits. If it isn't the lasts version, click on Find auto-detected Solver or input solver if OpenSEES is not installed on C. Then select solver you need on the list on the right of Run Analysis button.
Hope it is helpful
Have a nice day
Hope it is helpful
Have a nice day
yuweihwang
Thanks for your quick reply! May I ask you to share the link again? Because I cannot find anything when I use the link that you attached at last post.
Many thanks for your help!!
Sorry!!
You can find the sequential and parallel OpenSees 3.2.0 compiled by Pontifical Catholic University of Peru here:
https://www.pucp.edu.pe/profesor/sabino-tarque-ruiz
yuweihwang
Thank you for your help!
[email protected]
The rar file I retrieved via the google drive link posted on Prof. Ruiz's website is broken. Does anyone else have this issue or it's just for me? Can someone share the file on the forum for easy access, please?
Clarabella
It should work we just tried.
This link seems to work fine, as you can see in the gif attached.
Could you be more specific maybe or send a screenshot/gif?
- Untitled design (2).gif (478.57 KiB) Viewed 9557 times
[email protected]
It's all good, I've retrieved the file. Sorry for the trouble. It was a technical issue due to lost packages resulting from VPN malfunctioning.
Glad you were able to solve it!
I see that you are using a .cn address, are you unable to access the webpage to download the files from China without a VPN, or do you just use one customarily?
