Get the latest version of OpenSEES MP/SP
yuweihwang
Post by yuweihwang » Tue Jun 02, 2020 7:50 pm
Hello
OpenSEES recently release the new version of OpenSEES MP V3.2 and SP V3.2.
Is there any way to download those versions of exe files and connect it with STKO?
I tried to download those files from https://opensees.berkeley.edu/OpenSees/ ... rallel.php
However, they didn't allow us to download the files.
Thanks for any help!
bruno05
Re: Get the latest version of OpenSEES MP/SP
Post by bruno05 » Wed Jun 03, 2020 11:14 am
Hi!
it is possible to download lasts version of OpenSEES at the following link.
posting.php?mode=reply&f=28&t=1633
STKO will automatically use the last version installed on C, but you can check it on Edit Solver Kits. If it isn't the lasts version, click on Find auto-detected Solver or input solver if OpenSEES is not installed on C. Then select solver you need on the list on the right of Run Analysis button.
Hope it is helpful :)
Have a nice day
yuweihwang
Post by yuweihwang » Wed Jun 03, 2020 5:13 pm
Thanks for your quick reply! May I ask you to share the link again? Because I cannot find anything when I use the link that you attached at last post.
Many thanks for your help!!
bruno05
Post by bruno05 » Thu Jun 04, 2020 7:06 am
Sorry!!
You can find the sequential and parallel OpenSees 3.2.0 compiled by Pontifical Catholic University of Peru here:
https://www.pucp.edu.pe/profesor/sabino-tarque-ruiz
yuweihwang
Post by yuweihwang » Fri Jun 26, 2020 12:21 am
Thank you for your help!
[email protected]
Post by [email protected] » Tue Mar 02, 2021 6:36 am
The rar file I retrieved via the google drive link posted on Prof. Ruiz's website is broken. Does anyone else have this issue or it's just for me? Can someone share the file on the forum for easy access, please?
Clarabella
Post by Clarabella » Tue Mar 02, 2021 9:06 am
It should work we just tried.
HC2020
Post by HC2020 » Tue Mar 02, 2021 9:31 am
This link seems to work fine, as you can see in the gif attached.
Could you be more specific maybe or send a screenshot/gif?
Untitled design (2).gif (478.57 KiB) Viewed 9559 times
[email protected]
Post by [email protected] » Thu Mar 04, 2021 10:54 am
It's all good, I've retrieved the file. Sorry for the trouble. It was a technical issue due to lost packages resulting from VPN malfunctioning.
HC2020
Post by HC2020 » Fri Mar 05, 2021 7:58 am
Glad you were able to solve it!
I see that you are using a .cn address, are you unable to access the webpage to download the files from China without a VPN, or do you just use one customarily?
