I need help resolving an error when switching from ASD3D to RandomizedMaterialWrapper in an eccentric column model.
Issue:
Model works with ASD3D.
Fails with RandomizedMaterialWrapper, throwing:
invalid literal for int() with base 10: 'rebar' (new error).
Actions:
Checked material definitions, input files (attached), and documentation—no solution found.
Questions:
Are additional inputs required for RandomizedMaterialWrapper?
Could parameter parsing (e.g., string vs. integer) cause this?
Input files (working/error versions).
Error screenshot.
Thank you for your support.
Best regards,
Error: RandomizedMaterialWrapper "invalid literal for int(): 'rebar'"
- 57d6231a0197dd051207b2a55bc1737.png (233.71 KiB) Viewed 1405 times
- 9a1d7eac56154b735fc2baff4e74247.png (710.3 KiB) Viewed 1405 times
- model.zip
- (741.45 KiB) Downloaded 375 times
Re: Error: RandomizedMaterialWrapper "invalid literal for int(): 'rebar'"
I am writing to seek your technical support regarding an issue encountered during my recent testing. After troubleshooting, I identified that the problem likely stems from the Recorder function: the software operates normally when the Recorder is removed, but fails to generate output when the Recorder is enabled. This suggests a potential conflict or bug within the Recorder module. Could you kindly investigate this behavior?
Thank you for your prompt attention to this matter.
- ede55240324d5571ad49c73bea2f0e6.png (82.39 KiB) Viewed 1385 times
I cannot reproduce the error with my STKO version 4.0.0.
What version are you using?
