Reg! Error analysis did not converge
Posted: Wed Oct 01, 2025 12:37 pm
by Rajkanu
I'm trying do simplified micro model of an arch barrel with 10mm mortar thickness and the dimensions of the model are in mm. I'm interested to see stresses and strains and also wants to do eigen value analysis
Screenshot 2025-10-01 165704.png (208.42 KiB) Viewed 905 times
Screenshot 2025-10-01 165724.png (48.32 KiB) Viewed 905 times
Screenshot 2025-10-01 165739.png (49.79 KiB) Viewed 905 times
. When i do the analysis
Screenshot 2025-10-01 173932.png (27.58 KiB) Viewed 905 times
Screenshot 2025-10-01 174608.png (15.92 KiB) Viewed 905 times
Screenshot 2025-10-01 173949.png (19.91 KiB) Viewed 905 times
i'm getting this error
after: 1000 iterations current Norm: 0.0149585 (max: 1e-05, Norm deltaR: 0.518285)
NewtonRaphson::solveCurrentStep() -the ConvergenceTest object failed in test()
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.7
while executing
("for" body line 30)
invoked from within
"for {set STKO_VAR_increment 1} {$STKO_VAR_increment <= $initial_num_incr} {incr STKO_VAR_increment} {
# before analyze
STKO_CALL_OnBeforeAnalyze
(file "analysis_steps.tcl" line 435013)
invoked from within
AND WHEN I TRY TO CHANGE THE TEST COMMAND TYPE TO RELATIVE NORM UNBALANCE TEST
Screenshot 2025-10-01 174530.png (21.25 KiB) Viewed 905 times
I'M GETTING THIS ERROR MPCORecorder Error: cannot flush file on record()
Increment: 9 | Iterations: 2 | Norm: 7.894e+12 | Progress: 90.000 %
Increment: 10 | Iterations: 2 | Norm: 1.781e+13 | Progress: 100.000 %
Target time has been reached. Current time = 0.9999999999999999
SUCCESS.
ArpackSolver::Error with _saupd info = -9
Starting vector is zero.
WARNING DirectIntegrationAnalysis::eigen() - EigenSOE failed in solve() and i'm getting weird results
Screenshot 2025-10-01 165835.png (25.03 KiB) Viewed 905 times
please help me with the above
Re: Reg! Error analysis did not converge
Posted: Mon Oct 06, 2025 7:45 am
This is a simple non convergence error, cannot say much about it without a model
This is really bad! you are accepting an error of 7e12 units of forces!
This typically means you forgot masses
Posted: Mon Oct 06, 2025 8:47 am
by Rajkanu
I'm getting this as well src\H5AC.c line 1230 in H5AC_prep_for_file_flush(): slist enabled failed
major: Object cache
minor: Internal error detected
#008: C:\J\w\prod\BuildSingleReference\.conan\data\hdf5\1.14.0\_\_\build\f491c24a6c1b13acb3cc68e656f08b3ca13fc643\src\src\H5C.c line 2940 in H5C_set_slist_enabled(): slist already enabled?
major: Object cache
Increment: 9 | Iterations: 103 | Norm: 1.245e+06 | Progress: 90.000 %
Increment: 10 | Iterations: 113 | Norm: 1.991e+08 | Progress: 100.000 %
SUCCESS.
Using DomainModalProperties - Developed by: Massimo Petracca, Guido Camata, ASDEA Software Technology
# MODAL ANALYSIS REPORT and the results are also weird.
Posted: Tue Oct 07, 2025 7:32 am
major: Object cache
major: Object cache
Not an error, just a warning: The database could not flush to hard disk. Don't worry about that.
Don't you think your mass density is wrong?
How did you calculate it?
SW = 2.5e-5 N/mm^2
rho = about 2.5e-9! g = 9810 if you are modeling in mm!
Also, don't put the horizontal load in the gravity stage (which is load controlled), DO a displacement control analsys for that
Posted: Tue Oct 07, 2025 8:46 am
by Rajkanu
Thank you for your response
SW = 2.5e-5 N/mm^2
- - W=22kN/m^3 converted to mm
Screenshot 2025-10-09 115914.png (31.48 KiB) Viewed 408 times
Did you mean i have to use Displacement control integrator: define selection set and give the dof's and target displacements
Screenshot 2025-10-07 141054.png (32.19 KiB) Viewed 574 times
? and
why can't i apply the horizontal force as volume force on each solid as i did it in my above model?
Posted: Tue Oct 14, 2025 8:34 am
by Rajkanu
when i did displacement control analysis for the above i got this error Target time has been reached. Current time = 0.9999999999999999
SUCCESS.
TOTAL DURATION: 1.0
CYCLE 1 : nsteps = 10; dU = 10.0; dT = 0.1
Increment: 1 | Iterations: 1 | Norm: 3.983e-11 | Progress: 10.000 %
after: 40 iterations current Norm: 1.16655 (max: 1e-06, Norm deltaR: 671549)
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 86.8557
while executing
("for" body line 60)
invoked from within
"for {set i 1} {$i <= $ncycles} {incr i} {
set itime [lindex $time $i]
set itime_old [lindex $time [expr $i-1]]
set iU [lindex $U $i]
set iU_old [l..."
(file "analysis_steps.tcl" line 604406)
invoked from within
"source analysis_steps.tcl"
(file ".\main.tcl" line 81)
Plugin Library "pdm" correctly un-loaded
Posted: Tue Oct 21, 2025 7:50 am
SUCCESS.
TOTAL DURATION: 1.0
This one means that the previous analysis was fine
This one instead is a convergence error. The second time step did not converge.
Can you try using adaptive time step?
