Questions on Mass/Gravity Definition and Static Analysis for a Shaft Model in STKO
Posted: Sun Sep 28, 2025 8:28 am
I am building a 3D model of a shaft structure in STKO, which consists of side walls and a base slab. The base slab is modeled using brick elements (solid), while the side walls are modeled using ASDShellQ4 elements (shell). These two parts are connected using the beam-solid coupling constraint.
For the material, I have assigned Concrete01 to the structure. However, I still have some confusion regarding the definition of the structural mass and the application of gravity loads. I would appreciate your advice on this matter.
Finally, I attempted to run a simple static analysis but was unsuccessful. I have attached my model file and would be grateful for some suggestions to help identify the issue.
Thank you for your time and help. I look forward to your reply.
