interaction
ssimon
interaction
Post by ssimon » Wed Feb 26, 2025 7:16 am
Dear STKO team:
I used STKO to simulate the nonlinear dynamic characteristics of soil and tunnels, the software is very useful, but I have encountered some problems when using it, please help me check the model , the following is my model, it works normally.
1. I can't easily observe the fiber properties of the tunnel in the post-processing module;
2. There is a large gap between the soil and the tunnel, that is, the displacement of the soil has occurred, and the displacement of the tunnel is very small.
3. How to obtain the displacement of a node in the tunnel?
I would be deeply grateful for your guidance on this matter. Should you require any additional documentation or clarification, please don't hesitate to contact me . Thank you.
modelST.zip
(455.32 KiB) Downloaded 118 times
Re: interaction
Post by kesavapraba » Thu Mar 06, 2025 6:43 am
[1] Please attached file below. You can see the fiber Gauss points under 'Beam/Shell Fiber Color Map'
[2] This is strange. Check how you establish the interaction between the tunnel and soil elements
[3] Open a plot under 'Deformed Shape' -> Select the node where the displacement is required -> Go to 'Chart Data' -> Extract the data -> Just follow the prompted steps
