Hi STKO,
I am simulating a soil-pile interaction using py, tz, qz model. However, the piles are inclined with an angle of 20 deg with respect to vertical direction. Do you know how to create a local axis with an angle of 20 deg with respect to vertical direction? I can make a local axis with an angle, but I can not define a specific angle (20deg), as you can see in the attached figure.
Thank you for your support,
Buu
How to create a local axis with an angle
- local axis.JPG (11.69 KiB) Viewed 2243 times
Re: How to create a local axis with an angle
Hi, STKO allows the user to specify the local axis by asking to coordinates of axes directions. Please refer to the attached figure.
- localaxis.png (106.09 KiB) Viewed 2211 times
When you define the local axis you can define (either by clicking on existing points or by typing the 3 points of the local X-Y plane) the direction vectors.
The components of the normalized direction vectors are the cos and sin of your angles.
Just do your math knowing that:
- direction-X = normalized(second-point - first-point)
- direction-Y-temporary = (third-point - first-point) (just used to define the XY plane)
- direction-Z = cross(direction-X, direction-Y-temporary)
- direction-Y = cross(direction-Z, direction-X) -> make them orthogonal
