Page 1 of 4
Gap simualtion
Posted: Wed Mar 06, 2024 12:21 pm
by Lei Lei
Dear STKOteam:
I'm simulating a four-point bending experiment just like Figure 1 shows.
- figure 1
- 37eef323283d9d37cc1e1a9d4f9e1f0.png (35.15 KiB) Viewed 2821 times
However, there are three gaps in the middle joint of the separated curved beam.
- figure2
- 90399de4d1cd98f15307509dc3e6f58.png (11.54 KiB) Viewed 2821 times
Is there any way to simulate the behavior of gaps? With the gaps, the two parts of the curved beam will rotate and then touch each other.
Re: Gap simualtion
Posted: Thu Mar 07, 2024 10:35 am
Yes, it is possible to achieve that task using
zeroLengthContactASDImplex. Please refer to the webinar in the link below.
Re: Gap simualtion
Posted: Thu Mar 07, 2024 12:19 pm
by Lei Lei
Thanks for your reply!
To use a 2D beam with a fiber section to replace the solid curve beam, what should I do to simulate the gaps' behavior?
Does the method you recommend still work?
Re: Gap simualtion
Posted: Sat Mar 09, 2024 5:29 pm
Yes, you can still use the element by creating two auxiliary nodes at the vertex, where gap is simulated. It's because the beam element has 3 DOF at a node in 2D, but the zeroLengthContact element works with 2DOF in case of 2D problem. Hence, we need those auxiliary nodes. You can do it like:
1) create two auxiliary nodes (say, A and B) at the same location where the gap is present
2) connect left beam with A using equal dof interaction (only displacements)
3) similarly, connect right beam with B
4) use zeroLengthContact element between A and B
Re: Gap simualtion
Posted: Sun Mar 10, 2024 5:05 am
by Lei Lei
kesavapraba wrote: ↑Sat Mar 09, 2024 5:29 pm
Can I select two nodes on the ends of the beams instead of creating two auxiliary nodes?
Since the gap will rotate, Why don't you couple all DOFs of the auxiliary node and beam?
What's the difference between zeroLengthContact element and zeroLengthSection element?
I guess I also need to define a fiber section for the zeroLengthContact element to simulate the construction of the gap.
Re: Gap simualtion
Posted: Sun Mar 10, 2024 1:41 pm
No, it is due to the limitation of the number of degree of freedom imposed by the zeroLengthContact element. As already mentioned, beam element has 3 DOFs, whereas the zeroLengthContact can handle only 2DOF in 2D problems.
Gap cannot rotate, it is the structural elements that can deform and close the gap and make contact with each other. Coupling of the DOFS between the auxiliary nodes and the beam ends has nothing to do with gap rotation, it is because zeroLengthContact element can deal only with 2 DOFs at a node. For this reason, the auxiliary nodes need to be created. Had it been some quad/triangle element in 2D, you don't need the auxiliary nodes.
while both elements involve zero-length characteristics, the ZeroLengthContact Element is focused on modeling contact behavior, whereas the ZeroLengthSection Element is used for connecting points with a specific force-deformation relationship representation
Contact element doesn't require such definition. Please watch the webinar by Dr. Massimo which I shared in the previous answer.
Re: Gap simualtion
Posted: Sun Mar 10, 2024 1:51 pm
by Lei Lei
Thanks for your detailed explanation!
Best wishes!
Re: Gap simualtion
Posted: Mon Mar 11, 2024 5:42 am
You are welcome
Re: Gap simualtion
Posted: Mon Mar 11, 2024 11:04 am
by Lei Lei
Dear STKOteam,
I'm trying to simulate this curved beam with a complex gap in the middle using a 2D beam element and a zero-length section element.
However, It always comes up with a converge problem and my monitor doesn't show the wanted curve. Where is the problem?
I defined the section property and material for both beams and the gap. Is my modeling strategy correct?
Because I wanted to get the joint opening-moment curve at the gap, I outputted the rotation of one node coupled with another and the moment of the gap element. But the results were so strange.
Re: Gap simualtion
Posted: Tue Mar 12, 2024 5:57 am
Hi, It is challenging to understand your exact requirement. However, I can suggest you to look at zeroLengthContact incase if it helps.
