Page 1 of 2
meshing irregular solids
Posted: Mon Jan 29, 2024 1:08 pm
by ragopesa
Dear Stko team,
I hope you are doing well.
I have some issues with making a mesh in irregular solids. Could you please guide me how to do it?. Please find attached an example.
I already can run analysis and so on, but when I change to irregular "figures" the meshing just fail.
Salvador
Re: meshing irregular solids
Posted: Wed Jan 31, 2024 4:31 pm
Hi, Thank you for your message. It is not clear to us what you mean by "irregular" geometry. Can you please explain it?
Posted: Thu Feb 01, 2024 11:51 am
by ragopesa
Hi Kesavapraba !,
Thank you for your reply. I just noticed i upload the wrong example. Please, find attached the correct example.
I will be thoughtful to your reply
All the best,
Salvador
Posted: Thu Feb 01, 2024 1:36 pm
Hi, It seems there are some issues with geometry (possibility of having very short edges). Have you imported the geometry into STKO? If that is the case, you can export the solid geometry as *.stp file and import into STKO and do merge and then mesh it using unstructured tetrahedron option.
Posted: Thu Feb 01, 2024 4:28 pm
by ragopesa
Hi!
Thank you for your quick reply! I did, I imported the geometry. I did your recomendation, but I think the mesh is still wrong.
Could you please guide me?
Posted: Sat Feb 03, 2024 1:29 pm
Ok, can you please send me the stp file of the geometry? I will try to look at it.
Posted: Mon Feb 05, 2024 12:34 pm
by ragopesa
Hi!
Thank you so much for your reply. Please, do find attached the file. I will be thoughtful of your suggestions.
All the best,
Salvador
Posted: Tue Feb 13, 2024 6:25 pm
by ragopesa
Dear Stko team,
Do you have the time to check my file?
Salvador
Posted: Fri Feb 16, 2024 6:58 am
Hi, Sorry I tried my best to figure out the issues in your geometry. I could achieve meshing the top portion only. The geometry of the model is complex, particularly in the lower portion of the model, there can be some short edges that creates the issue. You can recreate the lower portion, add every small geometry in a step-by-step manner and simultaneously check for successful meshing. In this way you can come to know where the issue is.
Posted: Mon Feb 19, 2024 9:07 am
Also, the main issue with your geometry is that it comes from a STL or Obj (it's clear that it is tringulated). It would be better if you work on a clean geometry
