recommended values for the DAMAGETC3D parameters of C1 C2 C3 Gt Gc
xgx
Post by xgx » Thu Sep 28, 2023 10:38 am
Dear STKO team, I want to ask two questions.
Q1: Since there is no test data, are there any recommended values for the DAMAGETC3D parameters of C1 C2 C3 Gt Gc when I model masonry structures?
Q2: Are there any recommended values of the DAMAGETC3D parameters of C1 C2 C3 Gt Gc when I model concrete structures?
xgx
Re: recommended values for the DAMAGETC3D parameters of C1 C2 C3 Gt Gc
Post by xgx » Thu Sep 28, 2023 10:40 am
Dear STKO team if you can reply to my questions, I'd appreciate it.
ValentinaSB
Post by ValentinaSB » Fri Sep 29, 2023 7:24 am
Hi xgx,
There can not be a unique solution for those parameters. If you have a lack of data I will advise you to try ASDConrete3D material where you can use 1P preset. It will allow you to use a minimum of parameters and the rest will be calculated automatically. You can always then go into detail and try to calibrate better your parameters.
Screenshot 2023-09-29 091833.jpg (31.52 KiB) Viewed 3508 times
Valentina
xgx
Post by xgx » Fri Sep 29, 2023 8:12 am
Hi xgx,
Valentina
Dear Valentina,
Thank you for your advice, I'll try to model masonry structures according to your advice.
Best wishes to you.
xgx
ValentinaSB
Post by ValentinaSB » Wed Oct 04, 2023 7:36 am
You are welcome. Just remember that ASDConcrete3D fits better for the concrete (the formulas used for 1P preset based on MC2010 and some papers). Masonry parameters you will need to calibrate on experimental results.
Valentina
