ERROR IN PARALLEL ANALYIS
Posted: Wed Aug 30, 2023 6:04 pm
by Zeeshanbhat
Dear Team,
I am currently facing an issue with STKO after not using it for the last 6-7 months. I had been utilizing OpenSeesMP for parallel analysis, and my models were performing well without any problems. However, upon revisiting my models and attempting to analyze them again in STKO, I encountered an error that states: "Can't read process ID - no such variable exists."
PROCESS ID.png (41.7 KiB) Viewed 3551 times
Additionally, I noticed that there have been some additions in the code
compared to the previous version.
STKO 2.png (36.91 KiB) Viewed 3551 times
The model is attached below:
Modelbi.zip
(251.91 KiB) Downloaded 263 times
I would greatly appreciate any assistance or guidance you could provide to help me resolve this error
Looking forward to your prompt response.
Best regards,
Zeeshan
Re: ERROR IN PARALLEL ANALYIS
Posted: Thu Aug 31, 2023 6:01 pm
by Zeeshanbhat
I have attached the model also. The model was running fine in previous version of STKO. None of my model is working now. Kindly help in this regard.
Zeeshan
Posted: Tue Sep 05, 2023 8:15 am
by Zeeshanbhat
Gentle Reminder
Posted: Tue Sep 05, 2023 8:26 am
It's because you were running the analysis using a custom Tcl script that was compliant with the old STKO version.
However, now it should be sufficient to replace this line in your last analysis step:
I couldn't test it because I don't have your input GM, but let me know if it works
Posted: Wed Sep 06, 2023 6:24 am
by Zeeshanbhat
Dear Team,
Thank you for your assistance. I have analyzed the revised model with the correction you provided. Unfortunately, it is still displaying the same error.
I have attached the revised model along with the ground motion file for your reference. I kindly request your assistance in resolving this issue.
Thank you for your continued support.
Zeeshan Bhat
Posted: Wed Sep 06, 2023 2:32 pm
You have to change also every instance of process_id with STKO_VAR_process_id
here's a modified file:
Modelbi.zip
(256.97 KiB) Downloaded 205 times
Posted: Sat Sep 09, 2023 4:00 am
by Zeeshanbhat
Posted: Mon Sep 11, 2023 2:11 pm
