Page 1 of 2
Error of MPCO recorder in linux
Posted: Thu Feb 23, 2023 12:13 pm
by amb_1
When I used linux supercomputer system to calculate, the command model ran normally when I deleted mpco record. When I joined mpco, I encountered a new problem, I spent a week, but finally failed. Could you give me some advice?
The links to the opensees and methods I compiled are as follows:
https://github.com/MassimoPetracca/OpenSees
https://opensees.github.io/OpenSeesDocu ... build.html
Best wishes:
Re: Error of MPCO recorder in linux
Posted: Thu Feb 23, 2023 2:41 pm
The
STKO_VAR_process_id is automatically defined by STKO in the
main.tcl file.
If you just copy-pasted that piece of code inside a file which don't declare that variable you have that error.
Just put this lines at the very beginning of your tcl file:
# The current process id (from 0 to NP-1)
set STKO_VAR_process_id [getPID]
Posted: Fri Feb 24, 2023 3:43 am
by amb_1
Dear STKO Team:
I changed it according to the suggestion, but it still can't run. I used STKO to generate the code, but I don't know where the problem is. Can it run on your liux system (sbatch sub.sh), I have seen Massimo Petracca .PHD running STKO code on designsafe in linux, can you help me to see what is the problem? I have attached the code.
https://www.designsafe-ci.org/rw/worksp ... Simulation
Best wishes:
Posted: Fri Feb 24, 2023 8:00 am
Did you use
CMake to compile it?
- hdf5.png (20.89 KiB) Viewed 3999 times
It's because you compiled OpenSees with CMake without the MPCORecorder.
To compile OpenSees with the MPCORecorder (and also with the DRM class), you need to install the HDF5 library (version 1.12.0) in a location that CMake can find.
Posted: Fri Feb 24, 2023 1:28 pm
by amb_1
Dear STKO Team:
When compiling the program code, I used Cmake, is there any other reason? I asked my colleague to follow the tutorial to compile, but it's the same problem, when I delete the mpco record, the program runs normally, but when I join, I can't record the result normally. Can you give me some advice?
Best wishes:
Posted: Fri Feb 24, 2023 5:11 pm
If HDF5 1.12.0 is not installed in a directory that can be found automatically by CMake, you can help CMake find it by specifying the
HDF5_ROOT variable as the root of your HDF5 installation.
For example in Windows it is:
- hdf5.png (20.89 KiB) Viewed 3985 times
So I would use this:
cmake .. -DHDF5_ROOT="C:/Program Files/HDF_Group/HDF5/1.12.0"
Posted: Sat Feb 25, 2023 9:41 am
by amb_1
As for HDF5, we still have problems after installing HDF5, cmake found HDF5, we studied the source code. In the source code, it defined HDF5 as if def _HDF5, and then executed mpco, but we checked the hdf5 compilation file under linux. There is no definition of marco _HDF5 in it. Then we check the official website file of hdf5 and find that it exists in the shared library of hdf5.lib in windows version. Now the main problem is that we can't find the definition of _HDF5. We tried 1.12.0 and the latest 1.14.0 hdf5, but we couldn't find the definition.Forum You provided the definition of HDF5 for windows. Can you demonstrate the definition of HDF5 for linux?,For example in Linux
Posted: Mon Feb 27, 2023 8:00 am
The preprocessor macro _HDF5 is not in HDF5 itself, it is a macro required by OpenSees, so you should defined it in Cmakelist.
You are right, the CMakeList.txt contains an error.
It only defined the _H5DRM macro (used for the DRM object).
It should also define the _HDF5 macro
- _hdf5.png (25.28 KiB) Viewed 3888 times
Try this and let us know.
Posted: Mon Feb 27, 2023 2:36 pm
by amb_1
When using Linux system to Solve by OpenSeesMP, the model ran normally, but when using the site stress balance ,plastic analysis, I encountered a new problem. When the material changed from elastic to plastic after gravity balance, the linux system could not solve, the program is interrupted, but Widows ran normally . have downloaded the folder versions of Widows and Linux last time, can you help me to see it?
Best wishes:
Rujiang Pan
Posted: Mon Feb 27, 2023 2:52 pm
- Did you manage to compile using the _HDF5 macro?
Does it crash? or is it just hanging? or not converging?
Are you sure the Windows and Linux version are the same? I mean, you compiled them from the same source code?
