Truss element for brace modeling
Zonghu Pei
Post by Zonghu Pei » Fri Feb 17, 2023 8:34 am
I am modeling a BRB-precast concrete frame. Here I attach an image to show the model scheme. I used zeroLength element to simulate the rigid coonnection between brace and frame. For the brace which has two different section, it was given truss element.
However, this model did not work. I was wondering if I used unproper element or modelling method in this model. What should I do to correct is? Thank you!
BRB-frame.zip
(638.94 KiB) Downloaded 163 times
Re: Truss element for brace modeling
Post by STKO Team » Fri Feb 17, 2023 1:09 pm
You cannot discretize a truss element otherwise it will be singular.
You either model it as a single element (but you can't because you are assigning different section in the central part), or you can use beam elements, with beam-end releases
Zonghu Pei
Post by Zonghu Pei » Fri Feb 17, 2023 3:12 pm
Thanks for your reply!I used the truss element because it does not consider the out-plane deformation. You said that truss element may not suitable for my model. So here I have a question. If I use beam element to model the BRB(buckling restrained brace), what should I do to avoid the out-plane deformation?
Zonghu Pei
Post by Zonghu Pei » Sat Feb 18, 2023 8:21 am
Hello STKO team,
I have changed my model. In this model, I use a single truss element for brace. However, it still doesn't work. Is there any other things that I should pay attention to when use truss element?
brace frame.zip
(645.31 KiB) Downloaded 162 times
Post by STKO Team » Mon Feb 20, 2023 11:01 am
Here it is:
brace frame.zip
(610.58 KiB) Downloaded 171 times
Issues:
  • The torsion material is too high (1.0e20). It makes all other numbers look like 0 to a PC.... . When you use a stiff number you are following a penalty approach (as in the Penalty constraint handler). Therefore you need to compute a number which high enough, but not too high!
  • The truss MUST be discretized with only 1 element, otherwise the system will be singular
  • Don't use the lagrange constraint handler in the first analysis (it's diffucult to handle if you don't know the theory behind Lagrange Multipliers). I switched to Penalty
Zonghu Pei
Post by Zonghu Pei » Mon Feb 20, 2023 2:20 pm
Thans for your help! I will keep studying this software。 :idea:
Post by STKO Team » Mon Feb 20, 2023 2:44 pm
