Mesh erro
Wenyu
Mesh erro
Post by Wenyu » Sat Sep 10, 2022 3:28 am
An error happens while creating input files, this error is related to mesh type.
The model consists of line elements for rebar and solid elements for concrete. The model is a simulation of quasi-static test. I think the reason for the error is the wrong choice of element properties, so I made some changes, but the problem is still not solved.
I would be most grateful if you could help me with how to solve this error.
Wenyu
model.zip
(553.47 KiB) Downloaded 304 times
Re: Mesh erro
Post by STKO Team » Mon Sep 12, 2022 10:50 am
It's because you assigned the "beam element" (2 -nodes) to an interaction (163 nodes).
Please have a look at the webinar we gave.
There are many mistakes in this file:
- fiber sections are not properly defined
- boundary conditions for rigid links and embed constraints are not assigned
Wenyu
Re: Mesh erro
Post by Wenyu » Tue Sep 13, 2022 5:24 am
Thanks for you reply. I will check the model
Re: Mesh erro
Post by STKO Team » Wed Sep 14, 2022 7:31 am
