Try to mesh cylinder into hexa not tetra
Lin Sun
Post by Lin Sun » Thu May 12, 2022 1:22 am
I am trying to model a standard concrete cylinder. I noticed that I can only generate tetra mesh not hexa mesh due to the geometry limitation. Also I looked the following post (see the link) about the same issue (you have a hole in the cylinder in the middle so that you can generate hexa mesh).
viewtopic.php?f=29&t=2154&p=5580&hilit= ... Slip#p5580
I am still no able to generate hexa mesh in my model after I looked all the posts about the cylinder mesh. I have attached my model in this post. If you can help me with this I will be very thankful.
Lin Sun
cylinder.zip
(604.94 KiB) Downloaded 312 times
Lin Sun
Re: Try to mesh cylinder into hexa not tetra
Post by Lin Sun » Thu May 12, 2022 11:51 pm
I have figured out how to mesh a cylinder with hexa type mesh. I have uploaded my model with hexa mesh in this post in case other people may find it useful.
hexa_cylinder.zip
(816.29 KiB) Downloaded 289 times
Post by STKO Team » Mon May 16, 2022 1:50 pm
Great!
However, you can improve it. The way you did it makes the elements near the corner, almost singular (their jacobian at that point is close to 0):
A better approach is to:
  • draw a circle with the second point at 45 deg
  • draw an X and a Square
  • merge everything
  • in sub-selection mode, remove the inner X
  • make Planar faces
  • Mesh
