Analysis with OpenSeesMP does not show Monitor
w1289521589
I watch this video(https://www.youtube.com/watch?v=VY_EbSi2jvo) and run the downloaded file using OpenSeesMP. Although the result is successfully calculated, the Monitor is not displayed like the video. How can I solve this problem?
Clarabella
Re: Analysis with OpenSeesMP does not show Monitor
It depends on the setup and with MP it could happen. If it does not work, STKO writes a file in the folder of the analyis called: "LaunchSTKOMonitor.bat"
Launch this file after you lunch the analysis or even at the end, and you will see the monitor.
w1289521589
