I'm trying to model a beam with prestressing, assigning the initial stress to the steel. I have a couple of questions about the comand.
- When I select the initial stress it requires the tag of material and the initial stress as the label tells but below in the explanetion box is written 'initial strain'. I attached the image. Is just a problem of label or not?
Supposing that is a label problem, the analysis does not run when I put the right value of the initial stress (999 MPa) but runs when I put low values. In particular, the warning error says: "WARNING: InitStressMaterial - could not find initStrain to within tol for material: 3 wanted sigInit: 999 using tStress: 0"
I attached also the model (it is a high performance fiber reinforced concrete).
Thanks in advance
Antonella
Prestressing
AntoMarinelli
Prestressing
- HF600.5.rar
- (7.54 KiB) Downloaded 166 times
- Prestressing.PNG (41.3 KiB) Viewed 2357 times
Re: Prestressing
Dear Antonella,
in the model, you sent there is just the geometry.
Can you send me the correct one?
AntoMarinelli
Re: Prestressing
Oh, I'm sorry, it does not save the modifications.
I attached now
I attached now
- HF600.5.rar
- (223.62 KiB) Downloaded 190 times
Re: Prestressing
You defined a steel01 for your steel material to prestress with a 500 MPa maximum strength and then you try to apply higher stress, OpenSees it's just telling you that the steel is breaking. Normally steel cables for prestressing have a higher strength than 500. Either use a higher strength or an elastic material. Anyway check the constitutive behaviour of this kind of steel which is normally more brittle.
AntoMarinelli
Re: Prestressing
Yes, I'm sorry for the dumb question!
Antonella
Antonella
