Dear all,
In the STKO pre-processor, when defining a new Condition, under Model->Loads->Force, I see items such as "Face Force" that are not available in OpenSEES. How do they work exactly?
Distributed Loads
MassimoPetracca
Re: Distributed Loads
Dear Vicky,
You are right, objects such as FaceForce, EdgeForce, etc... do not have a direct counterpart in OpenSEES. They are STKO automations that simplify the way you can build your model.
For example, if you want to apply a distributed pressure of 10 F/L^2 on a curved shell, acting normal to its plane, in OpenSEES you would need to compute the equivalent nodal load vectors and write them in a load pattern using the load command.
In STKO, instead, you can use the FaceForce Condition, where you specify the distributed pressure vector in local coordinates (px = 0, py = 0, pz = 10). Then STKO will automatically compute the lumped nodal forces and will write them in the TCL file using the load command.
