Analysis Problems
Posted: Wed Dec 30, 2020 6:54 pm
by Alexandru%20BogdanDeac
I am facing convergence problems with the analysis of a rectangular concrete wall. The modeling was made based on the RC Shear Wall video posted on your YouTube channel with some adjustments for this specific model but I think the settings for the analysis are not quite good.
Attached to this message, please find the model.
Please help.
Happy New Year.
Best Regards.
Re: Analysis Problems
Posted: Tue Jan 05, 2021 9:25 am
Dear user,
We had a look at your file and here is a working copy of your original file:
Here are some changes I made:
- Your model was singular because the top node (control node, where you applied the displacement history) was not attached to the main wall. I added an interaction between the top node (master) and the wall top-edge (slaves), using a rigidLink boundary condition
- I increased the number of time steps. You are using the IMPLEX option in the DamageTC3D model. The IMPLEX algorithm makes the model always converging, but it requires small time steps.
- I changed your cyclic timeSeries. It was incorrectly starting from t = 1. However in your previous vertical analysis you reset the time to 0, so the cyclic timeSeries should start from 0.
- In order to impose a constant dU (displacement increment) for every dT, I changed the abscissas of your cyclic timeSeries, otherwise you waste too much computational time in the first cycles that are pretty small.
- Then you maximum imposed displacement is small. The imposed displacement is 1, and your timeSeries had a maximum of 0.01. So you where imposing a maximum of 0.01 mm. I increased it so that the maximum displacement is 10 mm.
- I also made the total duration of the timeSeries = 1 second (just for clarity, it is a static analysis to the real-time does not matter)
- I also added the monitor tool, that is useful for monitoring your analysis in real-time
Here is the output of your model:
- U1.png (128.88 KiB) Viewed 3487 times
- U2.png (61.66 KiB) Viewed 3487 times
Posted: Tue Jan 05, 2021 1:57 pm
Thank you very much. Yet, the monitor does not run. I get the attached message and the analysis does not go further. If I delete the monitor it is ok.
Posted: Tue Jan 05, 2021 3:50 pm
We fixed this problem in version 1.1.5. What version are you using?
Try to download the latest one.
Posted: Wed Jan 06, 2021 7:08 am
1.1.5
Posted: Thu Jan 07, 2021 9:34 am
Yeah you are right,
We fixed it in version 2.0.0 that will be released soon (not in version 1.1.5)
In the meanwhile, here's the fixed "monitor.py" file:
You can un-zip it and copy it in
"C:\Program Files\STKO\external_solvers\opensees\analysis_steps\Misc_commands"
replacing the existing one
Let us know if it works.
Posted: Fri Jan 08, 2021 8:23 am
Everything works fine now.
